It is currently Thu Aug 21, 2025 2:51 pm
PostPosted: Fri Nov 15, 2013 1:36 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
I will be finishing my first build (Lutz/BRW) shortly and I'm trying to decide on a finish. I know there are many options. I want to use a thin finish and if possible not get into spraying (I'm building my guitar in my living space). Is there an obvious finish to pursue? I do want it to be gloss. Thx.
Here's the link to my build: viewtopic.php?f=10101&t=41471
PostPosted: Fri Nov 15, 2013 1:49 pm
French polish
These users thanked the author Jim Watts for the post: Steven Bollman (Sun Nov 17, 2013 1:43 am)
PostPosted: Fri Nov 15, 2013 2:18 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
French polish is a good option, but it does take a bit to master the technique.
TruOil has been my first coice, but the old Rockhard varnish has also given me good results. They've change the formula, so you probably won't be able to find any of the non-poly stuff. Pratt & Lambert 38 has gotten good reviews, but I haven't tried it yet, I've still got an unopened can of Rockhard.
These users thanked the author Rodger Knox for the post: Steven Bollman (Sun Nov 17, 2013 1:43 am)
PostPosted: Fri Nov 15, 2013 3:28 pm
Last Name: Beaver
City: Lake Forest
If I was finishing without spray equipment I would probably put on an epoxy finishing resin, like zpoxy on the hardwood sections and top it with KTM 9. It can be brushed on without to much difficulty. You want fairly thin coats and will need 12-15 to give you a safe build thickness giving you room to sand out and buff to a high gloss.
If you are so inclined you might try french polish on the top. You can get a thin build with it. It will scratch easier than most of the other finishes but should be fine on the top.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Steven Bollman (Sun Nov 17, 2013 1:43 am)
PostPosted: Fri Nov 15, 2013 3:30 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Yep, French Polish sounds like exactly the finish you need to use. No spray equipment necessary, non-toxic, thin, and can build to a moderately high gloss. Get the O'Brien DVD that LMI sells. Well worth the money.
I am still amazed that such a noble finish can be achieved with simply liquor and bug sh!+.
These users thanked the author Goodin for the post: Steven Bollman (Sun Nov 17, 2013 1:43 am)
PostPosted: Fri Nov 15, 2013 3:45 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Nice work steve . Vy cool toolbox. Like your loofier vice with swivel .Is it a recycled old swivel chair ?. If I ever find one . that/s a great idea. Mine/s mounted on my d. fir/hem workbench, and always seems inconvenient
These users thanked the author ernie for the post: Steven Bollman (Sun Nov 17, 2013 1:44 am)
PostPosted: Fri Nov 15, 2013 4:29 pm
First name: Ringo
French polish... it's pretty much the only finishing method I don't hate.
These users thanked the author James Ringelspaugh for the post: Steven Bollman (Sun Nov 17, 2013 1:44 am)
PostPosted: Fri Nov 15, 2013 5:19 pm
Robbie has his streamable and downloadable online French Polishing course as well.
These users thanked the author James Orr for the post: Steven Bollman (Sun Nov 17, 2013 1:44 am)
PostPosted: Fri Nov 15, 2013 10:04 pm
First name: Greg
Last Name: B
City: Los Angeles
Weren't the original Larsons varnished? Oil varnish is doable indoors, and it's meant to be brushed. Just keep a couple windows open.
FP is also a great option. I actually find it kind of relaxing.
These users thanked the author Greg B for the post: Steven Bollman (Sun Nov 17, 2013 1:45 am)
PostPosted: Sat Nov 16, 2013 2:22 am
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, ernie. The vise stand is an old cast iron table stand that someone was tossing out if you can believe. I had my stereo amplifier on it for a few years, also used it as a cafe table base. It is really great as a base for the vise. I push it out of the way when I don't need it. It raises and lowers. It's kind of perfect.
PostPosted: Sat Nov 16, 2013 8:02 am
First name: Jim
Last Name: Kirby
+1 for french polish, Robbie's DVD or online lesson, and the other positive comments made above.
The hardest part to catch onto is how dry your pad is while you are working - it's not like brushing or wiping on a finish at all, and you get in trouble if you approach it that way.
This is not to say that you can't just brush on shellac. You can, and many people do, and then polish the surface using normal FP technique after they have gotten the finish built. But the two steps have to be treated each in their own way.
Jim Kirby
kirby@udel.edu
These users thanked the author Jim Kirby for the post: Steven Bollman (Sun Nov 17, 2013 1:45 am)
